Content Disarm schlägt fehl / Fehlermeldung 2148734208 / Ereignis 43289
citeq
30 März 2023
heute Morgen hatten wir ein paar Fehlermeldungen:
Schwere: Warnung
Event ID: 43289
Datum und Uhrzeit: 16.02.2026 06:51:25
Rolle oder Dienst: Gateway Role
Nachrichtendetails: Content disarm failed for attachment 'Speise KW.10 - 02.03.B.neu.xlsx' of email 'Speiseplan für die 10. KW in XLSX, jetzt auch mit dem richtigen Absender' (Message ID: <BE1P281MB315611EEA6811DE509DC3A7CEC6CA@BE1P281MB3156.DEUP281.PROD.OUTLOOK.COM>) sent on 16.02.2026 06:51:21 from 'adresse1@domain.de' to 'Adresse2@domain2.de'.
The attachment was uploaded to the Web Portal and quarantined. The email will be delivered to its recipient(s).
Eine Ausnahme vom Typ "Clients.PdfClient.Models.ProblemDetails" wurde ausgelöst.
Error code: 2148734208
A call to the external process manager failed.
Exception type: https://tools.ietf.org/html/rfc9110#section-15.6.1
Title: Bitmap decoding failed. 'WPF' (https://docs.microsoft.com/en-us/dotnet/desktop/wpf/) was not found on the system. If the platform on which the application is running supports 'WPF', make sure that your project uses it. 'System.Drawing' (https://docs.microsoft.com/en-us/dotnet/api/system.drawing) was not found on the system. If the platform on which the application is running supports 'System.Drawing', make sure that your project uses it. 'ImageSharp' threw an exception of type 'SixLabors.ImageSharp.UnknownImageFormatException' and with message 'Image cannot be loaded. Available decoders:
- PNG : PngDecoder
- Webp : WebpDecoder
- TGA : TgaDecoder
- TIFF : TiffDecoder
- PBM : PbmDecoder
- GIF : GifDecoder
- BMP : BmpDecoder
- JPEG : JpegDecoder
'. For more details about the exception, see the inner exception. 'GemBox' threw an exception of type 'System.NotSupportedException' and with message 'Specified method is not supported.'. 'SkiaSharp' threw an exception of type 'System.NotSupportedException' and with message 'SkiaSharp encountered an unknown bitmap decoding error.'.
Message: Eine Ausnahme vom Typ "Clients.PdfClient.Models.ProblemDetails" wurde ausgelöst.
Stacktrace:
bei Microsoft.Kiota.Http.HttpClientLibrary.HttpClientRequestAdapter.<ThrowIfFailedResponseAsync>d__28.MoveNext()
bei Microsoft.Kiota.Http.HttpClientLibrary.HttpClientRequestAdapter.<SendPrimitiveAsync>d__21`1.MoveNext()
bei Clients.PdfClient.Api.Pdf.ConvertExcelToPdf.ConvertExcelToPdfRequestBuilder.<PostAsync>d__2.MoveNext()
bei Netatwork.NoSpamProxy.MailValidation.ContentDisarm.<TryDisarmAttachmentAsync>d__8.MoveNext()
bei Netatwork.NoSpamProxy.MailValidation.ContentDisarm.<DisarmAttachmentAsync>d__3.MoveNext()
bei Netatwork.NoSpamProxy.MailValidation.ContentFilterMailOnHoldObserver.<DisarmContentAsync>d__34.MoveNext()
Was kann die Ursache sein? Muss hier ein Dienst neu gestartet werden?
Version aktuell: 15.5.0
Danke!
VG
Florian
Sorry für die Offtopic - aber ich feier den Anhang "Speise KW.10 - 02.03.B.neu.xlsx" 😂 - der Speiseplan hat bei uns auch hohe Prio ... Steht jedoch im Intranet.
Zu deinem eigentlichen Problem: Am besten mit Messagtrack und E-Mail (inkl. Anhang) sofern möglich beim Support melden, dann können die Jungs und Mädels sich das direkt anschauen, sofern es kein einmaliger Verschlucke war.
Hallo Florian,
Die Meldung macht mich etwas stutzig. Zwei Fragen dazu:
  1. Sind die Systemvoraussetzungen für die beteiligten Server, auf denen die NSP-Rollen installiert sind, vollständig erfüllt?
    Insbesondere mit Blick auf die eingesetzte .NET Framework-Version und fehlenden C++ Redistributableswäre das aus meiner Sicht noch einmal prüfenswert.
  2. Könnte es sich eventuell um eine defekte Datei handeln?
    Wäre es möglich, dass der Empfänger die betroffene Datei test weise auf einem anderen Weg (z.B. ZIP-Archiv, alternativer Transferkanal) zur Verfügung stellt, um auszuschließen, dass sie beim Transport beschädigt wurde.
